AAC Export Options
Jump to: navigation, search
AAC is a lossy, compressed audio format. It is the default audio format for Apple Music/iTunes®, iPhone®, iPad® and iPod®
Advice FFmpeg is not shipped with Audacity but you can download it and then export as AAC by following these instructions.
Accessed by: File > Export > Export Audio... then choosing M4A(AAC) Files FFmpeg from the Save as type dropdown menu
Also accessed by: File > Export > Export Multiple... then choosing M4A(AAC) Files FFmpeg from the Save as type dropdown menu.
In this case the options dialog will appear in the center of the Export Multiple dialog.
Format Options
  • Quality: This slider controls the quality (bit rate in kbps) of the output AAC file. The Maximum bit rate (best quality) is 320 kbps (stereo) 160 kbps (mono) and the minimum is 98 kbps (mono). The current quality setting is displayed in the center of the slider scale.
    The default quality setting of 160 typically produces a similar sized, but slightly higher quality file compared to an MP3 at Audacity's default 128 kbps constant bit rate. A stereo file is always produced, but a file exported from a mono track will have about half the bit rate (and hence half the file size) of one exported from a stereo track.
Tip You can use the keyboard left and right arrow-heads to move or fine-tune your slider position.
Advice Please be aware that there is a bug in Audacity whereby the bit rate setting that you make in an AAC export is not honored by Audacity. See this logged bug.
The workaround is to export as uncompressed WAV or AIFF and use iTunes to make the AAC conversion, see this page for information regarding this.
Peter 15May22: ToDo-2 this advice div can be removed if and when Bug 1818 gets fixed.
Like OGG, AAC encoding is a form of VBR or variable bit rate encoding, as opposed to the CBR or constant bit rate encoding used by default when exporting MP3 files.
This means that in order to maintain consistent quality throughout a track, a higher bit rate will be used when encoding a complex piece of audio (such as a full orchestral passage) than when encoding a solo voice or instrument. A recording which has more complex audio will produce a larger file. Increasing the sample rate in Selection Toolbar will increase the bit rate and so the file size (and vice versa).
