Application Preferences
Jump to: navigation, search
Linked This page is linked to in the Audacity app from the Help Button help button in the dialog.
Alert Do not rename or delete this page unless and until the corresponding link in the app is changed.
Pseudo renames can be achieved with a DISPLAYTITLE. If a rename is absolutely necessary then a redirect must be left behind.
Other languages
English
Application Preferences controls settings for the application. Currently there is only the single setting for updating Audacity but more settings will be added in the future.
Accessed by: Edit > Preferences > Application    (on a Mac Audacity > Preferences > Application )
Devices PreferencesPlayback PreferencesRecording PreferencesMIDI Devices PreferencesQuality PreferencesInterface PreferencesTracks PreferencesTracks Behaviors PreferencesSpectrograms PreferencesImport/Export PreferencesExtended Import PreferencesLibraries PreferencesDirectories PreferencesWarnings PreferencesEffects PreferencesKeyboard PreferencesMouse PreferencesModules PreferencesApplication PreferencesClick on this in Audacity to get helpPreferences Application.png
Click for details
Click in the left column for other preferences
Application Preferences.
Update Audacity
  • Check for updates: This enables you to turn Audacity update checking "on" or "off", it is "on" by default.
Audacity checks for updates to see if a new update of Audacity is available, it pops up a dialog informing you if and when an updated version of Audacity is available.
This is done on launch and then after every 12 hours while Audacity is open.
This is not an automatic update, update does not happen without you choosing to do so.
Tip The setting you make here is not reset by using Tools > Reset Configuration
Initial launch of Audacity
The first time that you launch Audacity after installing or updating you will see this dialog:
It has a direct link to Application Preferences enabling you to turn update checking "off" in order to opt-out of update checking.
