Apply Macro
Jump to: navigation, search
Peter 06Mar18:
Advice N.B. This page has multiple anchors in places. This is to deal with the 2.3.0 functionality where Macros replaced Chains - but also to deal with older pre-existing links in the Forum which still will link to the chain anchors.
Macros Palette automatically applies a series of preconfigured commands in a set order. The dialog allows you to select a Macro (which is a sequence of effect and/or export commands created using Tools > Macros then apply that Macro to either the entirety of the current project or to selected audio files in a single directory.
Tip Effect presets: since it is quite possible to have just a single command in a Macro you can use Macros to store your regularly used effects along with your favored settings.
  • This Macros Palette is useful for presets for effects. It stays open after applying a Macro, and you can pick another and apply that.
  • If you want, the presets can also adjust the selection. See Macros Examples for some suggested examples of this.
Contents
  1. Macros Palette
  2. Select Macro
  3. Apply Macro to Project
  4. Apply Macro to Files (batch processing)
  5. The buttons
  6. Examples
Macros Palette
Accessed by:
  • Directly from the menu Tools > Apply Macros > Palette, or
  • Using the Shrink button in the Manage Macros dialog
Macros Palette showing several user-added Macros as well as the as-shipped "MP3 Conversion" and "Fade Ends" Macros
Once invoked, the Macros Palette window will remain on-screen, actively available, at all times unless and until you dismiss it or close Audacity.
Select Macro
In the "Macro" list, left-click on a Macro (or use Up or Down keyboard arrow) to select the Macro you want to apply.
The typical purpose of this option is effect automation - apply a sequence of effects to the project, using effect parameters and an order of applying the effects that you have found to work well for the type of audio you are processing. This saves time and provides consistency in your workflow.
Use the Project button to apply the selected Macro to the current project.
The effects in the Macro are applied to the selected region of waveform in the selected audio tracks. Usually the selected Macro would not include an export command so as to use the greater flexibility of the Export Audio Dialog.
If an export command is included in the Macro, the entire project audio is exported irrespective of track or region selection. Therefore if the project contains multiple audio tracks, they will be mixed together, unless any of the tracks are muted on the Track Control Panel.
Peter 23Jul21: ToDo-2 If and when bug GitHub Issue #1288 gets fixed for consistent export behavior with Macros on projects this can be updated.
  • If the project has been Saved, then the exported files will be saved in a folder named "macro-output". The "macro-output" folder will be in the location specified in Directories Preferences.
  • If the audio in the project came from an imported file as its initial step (that is, it is a named project), the "macro-output" folder will also be in the location specified in Directories Preferences.
  • If the project has not been saved and is un-named, the normal Export Audio dialog will appear enabling you to choose the name and location of the exported file.
Tip Macros will work on pre-existing selections you make in your project prior to running the Macro. But the selection can be over-ridden by your Macro itself as there are macro commands available to effect selections in the audio. In particular Select All will select the entire project and Select which is parameterizable (see the provided Fade Ends Macro for an example where the first and last one seconds of the audio are selected for the fades).
The typical purpose of this option is batch processing - apply the Macro to multiple audio files so as to apply one or more effects to them, and/or convert them to another file format. You can convert from any file format supported by Audacity to WAV, MP3, OGG or FLAC.
Advice The selected Macro must include an Export step, otherwise the processed audio will not be retained.
Use the Files... button to apply the selected Macro to selected external audio files that are in a single directory.
  1. A standard File Open dialog box will appear. Choose a directory then you can select one or any number of supported audio files in that directory, including older AUP project files (but not AUP3 project files).
    • You cannot select files outside that directory, and files in folders inside that directory will not be processed.
    • It is convenient therefore to first put all the audio files you want to process into one folder before applying the Macro.
  2. After selecting the audio files you want to process, choose Open.
  3. Each file will be imported into Audacity and processed, exported to the format you chose in the Macro, then the processed audio will be removed so as to clear the temporary disk space that had been used.
  4. The exported files will be saved in a folder named "macro-output" in the folder specified in the Macro output field in Directories Preferences. The original files are not altered.
    • If you leave the entry for Macro output blank in Directories Preferences then Audacity will default to creating a folder called "macro-output" in:
      • Windows: C:\Users\<your username>\Documents\Audacity
      • Mac: /Users/<your username>/Documents
      • Linux: /home/<your username>/Documents
When a Macro is applied to files, the only option is to import and process the entire file.
  • Thus the entire file will be exported unless an action or effect in the Macro (such as Cut or Truncate Silence) removes some audio.
  • If modifying the audio before exporting, the Select Time function may be useful to select audio to remove or modify.
  • Some optional Nyquist plugins have parameters to trim or extend audio by a specific length and Nyquist can do calculations too, so it may be helpful to use Nyquist plugins from within a macro.
Restrictions
  • If you already have audio in the current project window, you must save and close that project using File > Close before applying a Macro to files.
  • Applying a Macro to multiple Audacity AUP3 project files cannot be done, instead you need to use Python scripting.
  • You cannot process multi-channel audio files (for example, 5.1 surround sound files) using Macros, even if Import / Export Preferences has been set to "Use custom mix". Any multi-channel files you import will be mixed down on export.
Tip It is recommended not to process more than 500 files at a time.
The buttons
Expand
Use the Expand to return to the full-size, full-function Manage Macros dialog.
The apply Macro buttons are also available on the Manage Macros dialog - so all Macro operations can be made from that full dialog.
Cancel to exit the dialog
To dismiss the dialog simply click on the Cancel button
Otherwise the dialog will remain open on the screen, but allowing you to perform other Audacity functions.
Macros Examples
See the Macros Examples page for examples of using Macros.
<  Manage Macros
|<  Back to: Macros
