Clip Fix
Other languages
English
Steve by email 23May17: ToDo ClipFix needs some attention. It has a known bug #1618 and an outstanding "feature request" to handle "inverted peaks". Hence the retention of the button.
Clip Fix... attempts to reconstruct clipped regions by interpolating the lost signal. It is only likely to be effective for repairing lightly clipped audio.
- Accessed by:
Threshold of Clipping (%)
How close to the maximum sample magnitude any sample must be to be considered clipped.
- If processing is slow, select only a few seconds of clipped audio at a time.
- This effect assumes that the audio is clipped at the same dB level for both positive and negative peaks. If either the top or bottom of the waveform is successfully reconstructed but not both, try applying DC offset correction before applying Clip Fix.
Reduce amplitude to allow for restored peaks (dB)
This enables you to reduce the amplification of the current selection (default is -9 dB) to provide headroom for the clip-fixed reconstruction.
