Edit Menu: Audio Clips
Jump to: navigation, search
Editors BEWARE - this page has a DISPLAYTITLE
Other languages
English
Items in the Audio Clips  cascading Edit menu let you create or remove separate clips in the audio track.
For more details on the use and management of clips please see Audacity Tracks and Clips
Mac users: Ctrl = and Alt = Option. So, for example, Ctrl + Alt + J = ⌘ + Option + J
Split  Ctrl + I
Splits the current clip into up to three clips at the selection boundaries. The audio before, within, and after the selection can now all be shifted independently
Split New  Ctrl+ Alt + I   Extra
Does a Split Cut on the current selection in the current track, then creates a new track and pastes the selection into the new track.
Join  Ctrl + J   Extra
If you select an area that overlaps one or more clips, they are all joined into one large clip. Regions in-between clips become silence.
Detach at Silences Ctrl + Alt + J   Extra
In a selection region that includes absolute silence and other audio, creates individual non-silent clips between the regions of silence. The silence in the selection becomes blank space between the clips.
If the selection is entirely silence, it becomes blank space between the audio either side of the selection.
<  Back to: Edit Menu
