Error: Disk full or not writable
Jump to: navigation, search
Linked This page is linked to in the Audacity app from the Help Button help button in the warning/error dialog.
Alert Do not rename or delete this page unless and until the corresponding link in the app is changed.
Pseudo renames can be achieved with a DISPLAYTITLE. If a rename is absolutely necessary then a redirect must be left behind.
This is essentially a landing page in the Manual for the handling of errors (via a Help Button help button) that occur in the Audacity application.
  • There is also an entry in FAQ:Errors so that this page will get pulled into the released Manual.
This error message is telling you that the disk you are using is full, or that the disk or file that you are trying to write to is write-protected.
Contents
  1. Disk is full
  2. Salvaging your project
  3. Write-protected files or disks
  4. Size occupancy
  5. Low disk space on startup
Peter 12Jan21: Use of FAT/FAT32 is blocked for saving and for temp files.
  1. FAT formatted limits - maximum file size 4GB
Disk is full
You get the following error message when you are trying to write to a disk that is full or if the disk or file is write-protected (or you do not have sufficient privileges to access it).
This can happen when you are:
  • Recording
  • Saving a project
  • Exporting from a project
  • Importing into a project
  • Applying effects
  • Editing
Disk full when editing
If your disk is filling up while editing you will see this warning message:
Disk full when Saving a project
If your disk does not have sufficient space to save a project you will see this error message:
To avoid losing the project there are three options:
1) Free up space on the disk
Free up some space on the disk you are working on.
Alert Do not delete the AUP3, WAL or (Windows only) SHM files for your project as part of this freeing up of space.
If your project is on your main internal drive, it may be possible to make a significant amount of space simply by emptying the recycle bin (Bin/Trash on Mac).
Further:
  • Windows: Just delete unwanted files and or folders with Shift + Delete
  • Mac: Move files and/or folders to the Bin/Trash then empty the Bin/Trash (Finder > Empty Bin/Trash). (If you do not empty the BinTrash the space will not actually be freed up.)
  • Linux: Use Delete to remove unwanted files and or folders. If your desktop uses "Move to Recycle bin / Wastebasket" this will not actually remove the files from the disk until you empty the recycle bin / wastebasket.
Advice Do not try to reduce space usage by deleting part of the project in Audacity, this will only try to take up more temporary space on the disk.
2) Save to a different, bigger, disk
File > Save Project As... or File > Export to a different disk with sufficient space.
You may still need to free up some space on the original disk for this to work, but not as much as for the above option.
3) Copy/Move the project files to a bigger disk
  • If the project was previously saved, you may use your operating system's file manager to copy or move the project files: AUP3, WAL (and SHM on Windows) to another disk with sufficient space. Then open the AUP3 project file from there with Audacity and close it to make it complete.
  • If the project was not previously saved, you may use your operating system's file manager to copy or move the project temporary files to another disk with sufficient space.
If Audacity is closed before the project has been saved, the temporary project files will be automatically and permanently deleted.
If Audacity has crashed, the project temporary files may (or may not) still be present and usable.
The default location of an unsaved project's temporary files are:
  • Windows: C:\Users\<your username>\AppData\Local\Audacity\SessionData
  • macOS /Users/<your username>/Library/Application Support/SessionData
  • GNU/Linux: /var/tmp/audacity-<your username>
Copy the entire "SessionData" ("audacity-<your username>" on Linux) folder to a new disk.
Advice Before restarting Audacity, ensure that there is a reasonable amount of disk space on the drive that has Audacity's temporary folder. To recover the project requires significantly more space than the folder that you have just copied.
To open the project, launch or restart Audacity, then from File > Open... search for the file with the extension ".aup3unsaved" in the copied folder. After recovery you will need to save the project or export your work.
It is also possible the the disk or file you are trying to write to is write-protected or you have insufficient privileges to write there.
You will need to change the write-protection to enable the file to be written but that assumes that you have sufficient privileges to do that.
Size occupancy
As a guideline, one hour of stereo recording at default settings (44.1kHz, 32-bit) occupies approximately 1.2 GB of disk space
Audacity will warn on start up or when using File > New to create a new project if you have 100 MB or less space in the temporary folder for recording or editing.
100MB is approximately 5 minutes of stereo audio or 10 minutes of mono audio at default settings.
This means that you are very low on disk space on the volume that holds your temporary Audacity work files (by default that is the system disk).
You either need to free up space on that volume or reset your temporary file storage be on a different volume with Directories Preferences.
FAT formatted file size limits
Disks or drives that are formatted as FAT/FAT32 are subject to a maximum file size limit if 4GB, this is about 3 hours 20 minutes of stereo at default Audacity settings.
So if your project or file exceeds this limit (and note you can exceed this limit with shorter projects if you have a lot of tracks or do a lot of editing) you will get an error even though the drive as a whole is not full.
Tip In this case freeing up space will NOT work:
  • nor will copying the AUP, WAL and SHM files to a non-FAT formatted drive,
  • you will need to File > Save Project As... or File > Export to a non-FAT formatted drive.
