Error: Opening or reading file
Jump to: navigation, search
Linked This page is linked to in the Audacity app from the Help Button help button in the warning/error dialog.
Alert Do not rename or delete this page unless and until the corresponding link in the app is changed.
Pseudo renames can be achieved with a DISPLAYTITLE. If a rename is absolutely necessary then a redirect must be left behind.
This is essentially a landing page in the Manual for the handling of errors (via a Help Button help button) that occur in the Audacity application.
  • There is also an entry in FAQ:Errors so that this page will get pulled into the released Manual.
Intro to be provided ...
Errors when Opening or reading file
The following two warning messages occur when you try to open or import a corrupted file.
Audacity failed to open a file in <drive>
Project file or audio file could not be opened - probably corrupt.
Audacity failed to read from a file in <drive>
Audio file or Project file could not be imported - probably corrupt.
