Exporting Audio
Jump to: navigation, search
Other languages
English
You must use one of the Export commands to make an audio file for playing on your music player, burning CDs or for use in other applications. Saving an Audacity project only makes a text file that tells Audacity how to work with the audio you see in Audacity itself.
Please be aware that when using Export or Export Multiple Audacity will only export tracks that are not grayed-out by use of the Mute or Solo buttons in the tracks' Track Control Panels. So what you hear by previewing with playback prior to export is what you will get in the Exported audio file.
  • When using Export Selected Audio, however, Audacity will Export the selection from all selected tracks even if some if those tracks are grayed-out and inaudible on playback.
Export Commands
There are two Export commands for exporting a single audio file. These let you export either the whole project or a selected part of it.
  • File > Export > Export Audio... exports all the audio tracks in the project. By default, multiple mono tracks are mixed down to a mono file, but if you pan any mono tracks to left or right or if there are any stereo tracks among the tracks to be exported, the tracks are mixed to a stereo file.
Note that the mono tracks are mixed to both the left and right channels of the resulting stereo file. See Mixing for details.
Export Multiple
Alternatively, you may export multiple audio files in a single process. This is useful when making a long recording or group of recordings that you want to export as separate songs. Selected tracks or regions are ignored when exporting multiple.
If there are multiple audio tracks, exporting multiple files split on labels will export a mix of the tracks for each labeled area.
Advice
For Export Audio, Export Selected Audio or Export Multiple, tracks on which the Mute button is pressed are not exported. There will be a warning if you export with all audio tracks muted.
Export Audio and Export Selected Audio Dialogs
The identical Export File or Export Selection dialogs enable you to select the file name, folder location, audio format (such as WAV or MP3) and any options for that format (such as file size compression or bit depth).
  1. Choose your folder location.
  2. Type the name of your audio file in the File name box.
    Tip Help with choosing the file name:
    • Avoid periods (dots) in the file name, or you will have to add the extension such as .wav or .mp3 at the end of the name.
    • Some characters cannot be used on all operating systems or for email or Internet use. Use A to Z or a to z characters, whole numbers (0 to 9) and underscores ( _ ) for maximum compatibility.
  3. Choose your file type (export format) from the Save as type dropdown.
  4. Press the Options... button.to check if the format has additional settings that control its quality.
  5. Press Save to export the audio.
See Export Audio Dialog for more detailed information on this dialog.
Export Multiple Dialog
The Export Multiple dialog has extra choices for whether exported files are split based on labels or audio tracks and whether numerical prefixes or suffixes are added to the name.
  1. Choose your export format from the dropdown (press the Options... button.to check if the format has additional settings that control its quality).
  2. Choose the export location - either over-type in the text box (use Create... to create the directory named in the box if needed) or browse for the folder to export to using Choose....
  3. Select whether splits are based on labels or tracks using the radio buttons in the Split files based on: box.
    • If exporting based on labels, put a check mark in checked checkbox Include audio before first label and choose a file name if you require an exported file for any audio to left of the first label.
  4. Select a numbering scheme for file names (none, numbering before or numbering after) using the radio buttons in the Name files: box.
    Advice Some characters cannot be used on all operating systems or for email or Internet use.
    When typing a folder name or file name (including Audacity track names, names in labels or the Export Multiple "file name" boxes) use A to Z or a to z characters, whole numbers (0 to 9) and underscores ( _ ) for maximum compatibility.
  5. Use checked checkbox Overwrite existing files to enable overwriting of existing files with the same name if desired.
  6. Click on Export to export the audio.
See Export Multiple for more information on this dialog.
Export Formats
There are a number of audio formats that Audacity, as shipped, can export to. Other formats can be added by installing extra software libraries.
Links
>  Importing Audio
>  LAME MP3 Export
>  FFmpeg import/export libraries for more formats
>  Metadata Tags Editor
