Import Filtering and Importer Order
Jump to: navigation, search
Other languages
English
Peter 10Jul11: This page has been created by "removing" it from the Importing Audio page, leaving a link to this new page there.
Using the Files of type: ... or Format dropdown menu in the Import and Open Audio Dialogs
The choice made in the "Files of type:" (Windows) or "Format" (Mac OS/X) dropdown menu in these dialogs does two things.
  1. It restricts the file list to files of that type (or those supported by that importer), according to the file extension.
  2. It chooses which importer to use.
The choices in the "Files of type:" or "Format" dropdown menu are:
  • All files
    • All files in the list are selectable, even those not supported by Audacity or FFmpeg
    • The built-in Audacity importers will be tried first, then FFmpeg (if installed)
  • All supported files
    • Only those files supported by Audacity or FFmpeg (if installed) are selectable
  • Audacity Projects
    • Only Audacity project files (.aup3 and older .aup) are selectable
    • No importer is involved, since you are opening an Audacity project, not importing an audio file
  • WAV, AIF and other uncompressed types
    • Only uncompressed files are selectable
  • Ogg vorbis files, FLAC files, MP3 files
    • Only files of the specified type are selectable
  • List of files in basic text format
    • Only files ending in .lof are selectable. See LOF Files for how to create and use LOF files.
    • The importer used will depend on the files pointed to by the LOF file.
  • FFmpeg compatible files - this option is only available if you have installed the optional FFmpeg extension.
    • Any file types supported by FFmpeg are selectable
    • The FFmpeg importer will always be tried first if "Attempt to use filter in OpenFile dialog first" in Extended Import Preferences is checked, otherwise the native importer will be tried first.
