Interface Preferences
Jump to: navigation, search
Linked This page is linked to in the Audacity app from the Help Button help button in the dialog.
Alert Do not rename or delete this page unless and until the corresponding link in the app is changed.
Pseudo renames can be achieved with a DISPLAYTITLE. If a rename is absolutely necessary then a redirect must be left behind.
Other languages
Accessed by: Edit > Preferences > Interface    (on a Mac Audacity > Preferences > Interface )
Devices PreferencesPlayback PreferencesRecording PreferencesMIDI Devices PreferencesQuality PreferencesInterface PreferencesTracks PreferencesTracks Behaviors PreferencesSpectrograms PreferencesImport/Export PreferencesExtended Import PreferencesLibraries PreferencesDirectories PreferencesWarnings PreferencesEffects PreferencesKeyboard PreferencesMouse PreferencesModules PreferencesApplication PreferencesClick on this in Audacity to get helpPreferences Interface.png
Click for details
Click in the left column for other preferences
Interface Preferences.
Display
  • Language: Changes the language of the menus and other on-screen text. Languages with non-Latin character sets require you to have the correct fonts installed on your system, otherwise the menus will display with ???? characters.
  • Theme: Audacity now comes supplied with four pre-configured, user-selectable themes: Light, Dark, Classic and High Contrast. This enables you to choose the look and feel you prefer for Audacity's interface. See the Themes page for more details.
Tip If you have good programming skills there is also a Custom theme which you can modify to create your own look and feel for Audacity.
    Choosing -96 dB or lower for the "Meter dB range" extends the lowest displayable dB range when in the Plot Spectrum window.
    The Meter Toolbars, the waveform and the Plot Spectrum window can be dragged out to display more gradation ticks and units within the chosen range.
Options
  • Show 'How to get Help' message at launch: Uncheck this to disable the default start up dialog that lists our help resources.
  • Show extra menus: Check this to see the extended menu bar.
  • Beep on completion of longer activities: Makes Audacity play a beep when activities lasting longer than a minute are completed. Visually impaired users may find this useful.
  • Retain labels if selection snaps to a label:
    • By default this option is unchecked, in which case a point label is deleted when you delete a selection that snaps exactly up to the label edge (as shown by the yellow Boundary Snap Guides) and includes the label in the selection. Similarly, a region label included in the selection is deleted when deleting a selection that extends from or outside one edge and snaps to the other edge.
    • When this option is checked, a label included in the selection is always retained if deleting a selection that snaps to one or both label edges. Even if this option is checked, the label will still be deleted if you select over a point label or over both edges of a region label. Checking this option also means that if you Effect > Repeat... an audio selection defined by a region label (for example, by clicking in the label to select it), or extend that selection past one edge only, the selection will be extended to include a single label. Without this option checked the selection would be extended to include extra labels.
  • Blend system and Audacity theme: Adjusts the theme provided by Audacity to be closer to the system theme, if they already are reasonably similar. This may lighten or darken the buttons.
  • Use mostly Left-to-Right layouts in RTL languages: Arabic, Hebrew and Farsi are all 'Right-to-Left' languages. Audacity has difficulty dealing with this. Audacity will put the menus on the right, and will make some other changes, but by and large Audacity will behave Left-to-Right. If you disable this option, Audacity will try to use Right-to-Left in more circumstances, and the interface will get confused, with for example some buttons missing. This option is only available in Windows.
Timeline
  • Show Timeline Tooltips: Timeline tooltips are visible when hovering over the Timeline. These tooltips are enabled by default.
    They are useful for indicating whether Timeline Quick-Play is enabled. Experienced users may find that the Timeline tooltips get in the way, so this option allows these tooltips to be disabled.
  • Show Scrub Ruler: The Scrub Ruler can be displayed or hidden using this setting.
