Measure RMS
Jump to: navigation, search
Other languages
English
Use the Measure RMS analyzer to measure the RMS (Root Mean Square) levels in a track.
The primary purpose of this plugin is to serve as an example for Nyquist Plugin writers, of how translations may be added to plugins. All other plugins that are shipped with Audacity have translations compiled into the main application, but this is not practical for additional plugins that are not shipped with Audacity.
The translation mechanism available for "third party" plugins is limited to translating messages only, and not the GUI. This plugin includes translations for 5 languages, though any number of languages may be added. Documentation for adding translations to Nyquist plugins can be found in the Audacity wiki.
This Analyzer is not enabled by default. To enable it, use Analyze > Plugin Manager  to open the Plugin Manager dialog. There you will find the file listed as "rms", but it will enable as Measure RMS.
Accessed by: Analyze > RMS
This is a simple analyzer which measures the RMS level of the selected audio.
It is similar to Analyze Contrast, but without all the additional accessibility functionality.
The example above is the measurement of a typical stereo track where what is measured is:
  • left channel
  • right channel
  • the stereo signal
If you use this analyzer on a mono track you will just get a single figure shown.
RMS is often used as an abbreviation for Root Mean Square. It is method of calculating a numerical value for the average sound level of a waveform. The RMS level (colored lighter blue in Audacity waveforms) equates very approximately to how loud the audio sounds.
