Multi-Tool
Jump to: navigation, search
Other languages
Multi-Tool mode on Tools Toolbar lets you access all of the four separate tools on this toolbar at once, depending on the location of the mouse and the modifier keys you hold down.
While paused, only Selection and Zoom are available.
Selection tool for selecting audio before modifying it.Envelope tool for modifying loudness of audio.Draw tool for changing the values of individual samples.Multi-Tool combines the actions of all five tools.ToolsToolbarMulti.png
The image above shows the Tools Toolbar with the Multi Tool selected.
  • Click on this link to learn more about the Tools Toolbar.
  • Click on other tools in the image to learn more about those tools.
Advice Selection Tool will always be selected upon reopening Audacity, irrespective of which of the separate tools was selected when you quit.
Using Multi-Tool
To use Multi-Tool Mode, click the Multi-Tool button button on the Tools Toolbar or press F6 on the keyboard.
Multi-Tool Mode automatically selects one of the four tools on the Tools Toolbar according to mouse moves and key presses. The mouse pointer changes to show which of its functions is currently available (the pointer will appear similar to the button for the relevant tool on the toolbar).
Selection Tool
Selection Tool is available when the mouse is in an area that does not trigger the Envelope Tool. The pointer will appear as image of selection pointer. See Selecting Audio with the Mouse for more details.
Click to position the cursor Drag cursor to select a region
Envelope Tool
Envelope Tool is made available by hovering the mouse pointer over the waveform either on the blue horizontal envelope boundary or at half the distance of the envelope boundary to the center line. The pointer then changes to EnvelopePointer.png . Click and drag with the mouse and then use envelope tool as you would use the standalone Envelope Tool.
You can drag from the half-way point You can drag from the envelope boundary
Dragging from the half-way point Dragging from the envelope boundary
Draw Tool
Draw Tool is made available by zooming in until you can see individual samples then hovering the mouse pointer close to the line joining the samples. The pointer then changes to a pencil tool DrawCursor.png and you can use it as you would use the standalone Draw Tool.
Draw Tool prior to making a repair Draw Tool after drawing the repair
Zooming
For horizontal scale zooming.
Zoom out
Right-click (Ctrl + click on a Mac) the mouse at a point to zoom-out by a factor of 2, centered on the click point.
Note that even though you are zooming out the zoom cursor magnifying glass inconsistently shows "+" zoom-in iconography.
Zoom in
Right-click, drag and release to zoom-in to a drag-selected region.
Tip If you commence a horizontal or vertical drag to zoom by mistake, you can press Esc before releasing the mouse button to cancel the zoom operation.
The illustration below shows a right-click drag zoom-in.
A right-click rightward drag to define the horizontal zoom Releasing the right mouse button effects the zoom
Vertical scale zooming works, as normal, with any of the separate tools selected.
