Playback Preferences
Jump to: navigation, search
Linked This page is linked to in the Audacity app from the Help Button help button in the dialog.
Alert Do not rename or delete this page unless and until the corresponding link in the app is changed.
Pseudo renames can be achieved with a DISPLAYTITLE. If a rename is absolutely necessary then a redirect must be left behind.
Other languages
Accessed by: Edit > Preferences > Playback    (on a Mac Audacity > Preferences > Playback )
Devices PreferencesPlayback PreferencesRecording PreferencesMIDI Devices PreferencesQuality PreferencesInterface PreferencesTracks PreferencesTracks Behaviors PreferencesSpectrograms PreferencesImport/Export PreferencesExtended Import PreferencesLibraries PreferencesDirectories PreferencesWarnings PreferencesEffects PreferencesKeyboard PreferencesMouse PreferencesModules PreferencesApplication PreferencesClick on this in Audacity to get helpPreferences Playback.png
Click for details
Click in the left column for other preferences
Playback Preferences.
Effects Preview
  • Length: The length of audio to be played when previewing an effect, in seconds. Playback begins from the start of the selection region, and stops after the preview length has elapsed, or at the end of the selection region if that is shorter than the preview length.
Cut Preview
These preferences apply when using the Play Cut Preview (shortcut (C by default) to play a length of audio before and after a selection region. This is useful to hear what a cut would sound like before making the cut.
  • Before cut region: How much audio to play before the region.
  • After cut region: How much audio to play after the region.
Seek Time when playing
  • Short period: The time interval the playback cursor skips backwards or forwards when you press the (left arrow) or (right arrow) shortcuts respectively. The shortcuts , or . respectively can be used instead for short skip backwards or forwards.
  • Long period: The time interval the playback cursor skips backwards or forwards when you press Shift + ← (shift and left arrow) or Shift + → (shift and right arrow) respectively. Holding Shift with , or . respectively can be used instead for long skip backwards or forwards.
These two values also control the Cursor Long Jump and Cursor Short Jump commands when playback is stopped. The shortcuts , (comma) or . (period) jump the cursor backwards or forwards respectively by the Short Period interval; Shift + , or Shift + . jump the cursor backwards or forwards by the Long Period interval.
Options
  • Vari-Speed Play: With this checked, the speed of Play-at-Speed can be varied dynamically as you play audio. However skipping and seeking using the left-arrow and right-arrow keyboard keys is disabled. The default setting is "on".
With Vari-Speed Play turned "on", some machines may experience clicky playback if you have extremely low setting for you buffer size (less than 20 ms or 30ms if you are using the default MME host on Windows).
  • Micro-fades: With this checked, audio playback will make volume changes more smoothly, over a few milliseconds. This leads to fewer clicks when pausing audio, starting or stopping playback muting or unmuting or changing volume or pan whilst playing. The default setting is "off".
  • Always scrub unpinned: With this option enabled (default setting) scrubbing and seeking will ignore the pinned play head (if you have turned that option "on" from the Timeline) playing with a non-fixed play head. This has the effect of ensuring that it is the play head that moves while scrubbing/seeking rather than the waveform moving.
