Reset Configuration
Jump to: navigation, search
This resets your Audacity configuration (preferences, export settings and toolbars) to default settings.
Advice Be aware that this command acts immediately with no dialog and no choice of actions or chance to abort.
Undo is not available for this command.
Accessed by: Tools > Reset Configuration
There is no dialog associated with this command
Preferences and Export settings reset
Preferences
Using Reset Configuration will reset all your Audacity Preferences settings to their default "factory settings".
The exception is the setting for "Check for updates" in Application Preferences, which remains unaltered with the use of this command.
Modules
Any modules will no longer be listed on the modules preferences page, and will be searched for afresh next time you restart Audacity.
Export settings
Any export format settings from your last use of any export command will be reset to default by using Reset Configuration
Toolbars reset
Using this command will also reset all your toolbars to their default "factory settings": sizing, positioning and settings. This is analogous to using View > Toolbars > Reset Toolbars.
  • Tools toolbar: reset to "I-beam" Selection tool
  • Meter toolbars: recording and playback meters are both reset to Gradient style, dB type and Automatic orientation
  • Device toolbar: this is reset to the default Host with the default Recording and Playback devices for your computer - and reset to 2-channel stereo
  • Selection toolbar: reset to show:
    • Start and End of Selection
    • Time format reset to hh:mm:ss + milliseconds
    • Snap-To is reset to be "off"
    • Project Rate reset to the default 44,100 Hz
  • Time toolbar: resets the time format to hh:mm:ss
The sliders for levels in Mixer toolbar and the speed in the Play-at-Speed toolbar are left untouched.
Window size
The size of your Audacity window will be reset to its default size with this command.
It will not be placed in its default centre screen position.
What is not reset
Settings in Preferences
  • Update Checking: the setting you make in Application Preferences for update checking is not changed by Reset Configuration.
Settings in Effects Generators and Analyzers
  • Plugin Manager: the Enabled / Disabled settings that you have made for Effects, Generators and Analyzers will not be changed.
  • User Presets that you have saved for any Effect, Generator or Analyzer will not be removed by Reset Configuration.
Importantly this includes equalization settings you may have made in Filter Curve EQ and Graphic EQ.
  • Last-used parameter settings that you may have used in any Effect, Generator or Analyzer are not reset to default values.
If you need or want to reset these to Factory default values for any particular Effect, Generator or Analyzer please use the Manage button and choose Factory Presets.
Font setting for Label tracks
  • The global Font setting made in any label track's drop-down menu is not changed by Reset Configuration.
Recent Files
The recent files available from Files > Recent Files is not cleared and remains intact.
James: However, if you do Reset Configuration and then force quit Audacity, it is lost. This is probably more detail than is useful, or than users really need to know.
Plugins
Any plugins that you have added will not be removed.
Macros
Macros that you have created will not be removed or altered by using this command.
Full reset
If you require a full reset to make all Audacity settings the way the were when Audacity was installed then please see this FAQ.
Be aware that doing so will also remove all the items above in What is not reset as well as the items in Preferences and Export settings reset.
