Selecting Audio - the basics
Jump to: navigation, search
This is a landing page for the proposed Help button in the error message that the user gets if they try to apply an action that requires a selection with no selection extant. Just the bare minimum here, as users landing here want to get on with applying an effect. They can come back for more, once past that roadblock.
Alert Therefore please do NOT extend this Page.
This page explains only the basics of selecting audio for typical Audacity use. This involves either:
Once all or a region is selected, you can then change that selection's sound with an effect. Another common action is to delete or move the region of audio.
This page is only a brief summary of how to make selections in your project. For further details and visual examples please see the Selecting Audio page.
IBeam.png Selecting a region using the mouse
The easiest way to select a region of audio is to click the left mouse button anywhere inside of an audio track, then drag (in either direction) until the other edge of your selection is made, then release the mouse.
If Selection tool is not selected (default setting), choose IBeam.png from Tools Toolbar, below:
Tools‎ Toolbar
Selecting the whole of an individual track
The whole of an individual track can be selected by clicking in the Select button in the Track Control Panel to the left of a track.
Selecting the entire project
You can select the entire length of all tracks on screen with Select > All or use the shortcut Ctrl + A (or ⌘ + A on a Mac).
Links
> Forward to: Selecting Audio
|< Back to: Getting Started
