Size limits for WAV and AIFF files
Jump to: navigation, search
Linked This page is linked to in the Audacity app from the Help Button help button in the error dialog when attempting to create a WAV file bigger than 4GB.
Alert Do not rename or delete this page unless and until the corresponding link in the app is changed.
Pseudo renames can be achieved with a DISPLAYTITLE. If a rename is absolutely necessary then a redirect must be left behind.
Peter 21Apr19: This table is replicated on Export Formats supported by Audacity.
WAV and AIFF files are limited to a maximum size of 4GB, see the following table for how this translates to time durations
Approximate maximum time durations for WAV and AIFF PCM-encoded files
Maximum sizes for files in time duration (hours:minutes)
Sample Format Stereo Mono
16-bit (default) 6h:45m 13h:31m
24-bit 4h:30m 9h:01m
32-bit 3h:22m 6h:45m
Tip These timings are the theoretical maximum times. You would be well-advised to restrict yourself to slightly lower limits to afford some head-room.
Peter 23Apr19: Table based on 4GB = 4,294,967,296 bytes - see talk page for alternatives
