Sound Finder
accordingly no anchors on this page should be renamed or deleted.
| Do not rename or delete this page unless and until the corresponding link in the app is changed. Pseudo renames can be achieved with a DISPLAYTITLE. If a rename is absolutely necessary then a redirect must be left behind. |
| N.B. Although for Audacity 3.0.0 onwards this plugin has been replaced by Label Sounds this page must remain in the Manual as users who upgrade from 2.4.2 or earlier will still see this plugin in their Analyzer menu and if they use that plugin they may click on the |
| This effect has been superseded by the much-improved Label Sounds. You can still continue to use this analyzer if it is present in your Audacity app as a result of an earlier Audacity version download. |
After typing the name of the track or section in each label, will export audio files in one process corresponding to each label's audio. See Splitting a recording into separate tracks.
If you already have a label track and that is included in the selection that you make for the analysis then these labels will be added to your selected label track - possibly causing confusion with your existing labels.
- Accessed by:
Sound Finder divides up a selection by placing region labels for areas of sound that are separated by silence. Use this to make the labels show the exact region of each track to be exported. This lets you remove some or all of the silence between the tracks.
If any album tracks have more than one label, increase the silence level and duration. If any labels extend into other album tracks, reduce the silence level and duration.
Buttons
Clicking on the command buttons give the following results:
- gives a dropdown menu enabling you to manage presets for the tool and to see some detail about the tool. For details see Manage presets
- applies the effect to the selected audio with the current effect settings, but unlike the effect runs in debug mode. This is primarily of use when writing or editing Nyquist plug-ins.
- In addition to the normal plug-in behavior, a "debug window" opens to display error messages, normally the debug window will be empty
- applies the effect to the selected audio with the current effect settings and closes the dialog
- aborts the effect and leaves the audio unchanged, closing the dialog
Examples
See Silence Finder and Sound Finder for examples comparing and contrasting the usage of Silence Finder and Sound Finder.
