USB Recording
Peter 27Feb17: I think it is well worth having this page as part of "Getting Started" (in addition to the detailed page linked to in the intro) as many of our users start out with USB TTs or tapedecks - and drift into problems almost immediately.
This is a very basic guide to recording with USB devices. More detailed information (and Mac instructions) can be found at Recording with USB turntables or USB cassette decks.
| If you have just made a recording it is strongly recommended that you immediately export your audio using to WAV or AIFF (ideally to an external drive) as a safety copy before you start editing the project. |
- Connect the USB cable of the turntable, or tapedeck, to the computer, then launch Audacity. If Audacity was already running when you connected the cable, restart Audacity or choose .
- Use the Device Toolbar to set the recording and playback devices and set the channels to "2(stereo) Recording Channels":
- In this example on Windows, the output is set to the named speakers of the built-in computer sound device, the input is set to the USB turntable (usually called or including the phrase "USB Audio CODEC") and recording channels are set to stereo. Windows 10/8/7 calls most USB external devices "microphones". Some higher-end USB recording interfaces may appear as their explicit manufacturer's name.
- From the Transport Menu check "Software Playthrough" to be "on" to hear the turntable through the computer speakers. This setting can be toggled on/off easily using .
- Then, ignoring any instructions in the manufacturer's guide to select "stereo mix", simply press the Record button
on Transport Toolbar.
